Upgrade Issues
i'm using Windows10 - the upgrade caused some serious issues:
- start button is not working anymore
- show desktop button is not working anymore
- alt-tab shows minimal layout (like from xp, only icons)
- all icons on my desktop were re-arranged
- keyboard switched from german to english
i'm aware, it makes no sense downgrading, as my system settings were changed ..
any ideas how to fix this?
thanks
Hello fuxi,
Is this a problem with teamviewer?
Thank you for using teamviewer?
Iain Wels,
ICT-Support
yes, these problems occured directly after installation.
I found a solution meanwhile:
i had to terminate + restart explorer.exe in the taskmanager and anything worked again (except the rearranging of the icons), not sure about the keyboard switch.
thanks
