Remove splash screen TeamViewer Host 12
How to remove the splash screen that pops up after each restart.
Teamviewer Host 12 installled on Windows 10.
Untick the checkbox Don't show this dialog again is not saving the preference.
This is a very annoying bug that should be fixed !!!
I have tried already this fix but it's not working:
reg add "HKCU\Software\TeamViewer\VersionX" /v HostInfoDialog /t reg_dword /d 0 /f
  • I would suggest Teamviewer to remove showing on start this splashscreen until the use of check box is fixed. It's annoying for the users. It's also annoying if the host is on a remote PC doing commercial display. Very annoying.
