Failure Installing TeamViewer v13 beta on Linux Mint v18.1
Trying to install v13 beta and getting error:
Error: Breaks existing package 'teamviewer:i386' conflict: teamviewer-host().
I've already updated my Windoze installations, and now my Linux box is inaccessible.
  • Iain_wels
    Iain_wels Posts: 54 ✭✭
    Hello DickHildreth,
    From my notice you already have teamviewer host installed on you're computer. If you could delete the teamviewer host that is on you're computer (with delete all my file's on), maybe you can install the teamviewer then!
    I hope this helps,
    Thank you for using teamviewer!
    Iain Wels,
    ICT-Support
