Computers & Contacts panel appears on bootup
On one computer the Computers & Contacts panel appears every time Windows boots. Of the dozen or so computers I know that have TeamViewer installed, only one exhibits this behavior. Is there a way to prevent this from happening?
Best Answers
  • Mark3
    Mark3 Posts: 2
    I have same issue despite I unchek that option. Every time I start TW its keep showing.
    Also some script error shows every time I close TW. Tried to reinstall it few times but problem stays (and above issue too).
  • bartlanz
    bartlanz Posts: 315 ✭✭✭
    Interestingly enough, It is checked off on my computer and DOES NOT show up for me... ODD... The other error you are receiving I've seen before, But I can not remember what they said caused it. I'm pretty sure it was fixed in a release a few months ago though. Have you tried updateing your TeamViewer to the most current build?
    Bart Lanzillotti
    We Do IT USA
    www.wedoitusa.com
  • Mark3
    Mark3 Posts: 2
    I have latest build. Tride everything but without luck. Strange.
  • Zacks
    Zacks Posts: 1
    I have the same problem. I couldn't find any solution......
