Installing teamviewer on Ubuntu 16.04 reproducibly breaks my monitor setup
TL;DR. My system has dual video cards (three monitors). This works great, but when I install teamviewer 12 the second card disappears. Why? How do I fix it?
My system has dual video cards:
$ lspci | grep VGA
01:05.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] RS880 [Radeon HD 4200]
02:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Cedar GL [FirePro 2270]
I have three monitors hooked up (two on RS880 integrated graphics, one on Cedar GL discrete graphics).
Here is what xrandr says:
$ xrandr
Screen 0: minimum 320 x 200, current 4240 x 1050, maximum 8192 x 8192
VGA-0 connected 1280x1024+0+0 (normal left inverted right x axis y axis) 376mm x 301mm
1280x1024 60.02 + 75.02*
1280x960 60.00
1152x864 75.00
1024x768 75.08 70.07 60.00
832x624 74.55
800x600 72.19 75.00 60.32 56.25
640x480 75.00 72.81 66.67 60.00
720x400 70.08
DVI-0 connected primary 1680x1050+1280+0 (normal left inverted right x axis y axis) 474mm x 296mm
1680x1050 59.88*+
1280x1024 75.02 60.02
1280x960 60.00
1152x864 75.00
832x624 74.55
720x400 70.08
DisplayPort-1-0 disconnected
DisplayPort-1-1 disconnected
DVI-1-0 disconnected
DVI-1-1 connected 1280x1024+2960+0 376mm x 301mm
1280x1024 60.02*+
1152x864 75.00
1024x768 75.08 75.03 60.00
832x624 74.55
800x600 75.00 60.32
640x480 75.00 60.00
720x400 70.08
1280x1024 (0x48) 108.000MHz +HSync +VSync
h: width 1280 start 1328 end 1440 total 1688 skew 0 clock 63.98KHz
v: height 1024 start 1025 end 1028 total 1066 clock 60.02Hz
1152x864 (0x49) 108.000MHz +HSync +VSync
h: width 1152 start 1216 end 1344 total 1600 skew 0 clock 67.50KHz
v: height 864 start 865 end 868 total 900 clock 75.00Hz
1024x768 (0x4a) 78.800MHz +HSync +VSync
h: width 1024 start 1040 end 1136 total 1312 skew 0 clock 60.06KHz
v: height 768 start 769 end 772 total 800 clock 75.08Hz
1024x768 (0x4c) 65.000MHz -HSync -VSync
h: width 1024 start 1048 end 1184 total 1344 skew 0 clock 48.36KHz
v: height 768 start 771 end 777 total 806 clock 60.00Hz
832x624 (0x4d) 57.284MHz -HSync -VSync
h: width 832 start 864 end 928 total 1152 skew 0 clock 49.73KHz
v: height 624 start 625 end 628 total 667 clock 74.55Hz
800x600 (0x4e) 49.500MHz +HSync +VSync
h: width 800 start 816 end 896 total 1056 skew 0 clock 46.88KHz
v: height 600 start 601 end 604 total 625 clock 75.00Hz
800x600 (0x4f) 40.000MHz +HSync +VSync
h: width 800 start 840 end 968 total 1056 skew 0 clock 37.88KHz
v: height 600 start 601 end 605 total 628 clock 60.32Hz
640x480 (0x50) 31.500MHz -HSync -VSync
h: width 640 start 656 end 720 total 840 skew 0 clock 37.50KHz
v: height 480 start 481 end 484 total 500 clock 75.00Hz
640x480 (0x51) 25.200MHz -HSync -VSync
h: width 640 start 656 end 752 total 800 skew 0 clock 31.50KHz
v: height 480 start 490 end 492 total 525 clock 60.00Hz
720x400 (0x52) 28.320MHz -HSync +VSync
h: width 720 start 738 end 846 total 900 skew 0 clock 31.47KHz
v: height 400 start 412 end 414 total 449 clock 70.08Hz
My system is fully up to date:
$ sudo apt-get upgrade
Reading package lists... Done
Building dependency tree
Reading state information... Done
Calculating upgrade... Done
The following packages were automatically installed and are no longer required:
libasound2:i386 libexpat1:i386 libfontconfig1:i386 libfreetype6:i386 libice6:i386 libjpeg62:i386 libpng12-0:i386 libsm6:i386 libx11-6:i386 libxau6:i386 libxcb1:i386 libxdamage1:i386 libxdmcp6:i386
libxext6:i386 libxfixes3:i386 libxinerama1:i386 libxrandr2:i386 libxrender1:i386 libxtst6:i386
Use 'sudo apt autoremove' to remove them.
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
But when I install the teamviewer package:
$ sudo dpkg -i teamviewer_12.0.71510_i386.deb
Selecting previously unselected package teamviewer:i386.
(Reading database ... 213764 files and directories currently installed.)
Preparing to unpack teamviewer_12.0.71510_i386.deb ...
Unpacking teamviewer:i386 (12.0.71510) ...
Setting up teamviewer:i386 (12.0.71510) ...
Processing triggers for mime-support (3.59ubuntu1) ...
Processing triggers for hicolor-icon-theme (0.15-0ubuntu1) ...
And reboot...
My second video card completely disappears from xrandr and my third monitor stops working:
$ xrandr
Screen 0: minimum 320 x 200, current 2960 x 1050, maximum 8192 x 8192
1280x960 60.00
1152x864 75.00
832x624 74.55
720x400 70.08
1680x1050 59.88*+
1280x960 60.00
1152x864 75.00
832x624 74.55
The monitor attached to it no longer works, instead it displays the 'kubuntu' boot logo forever.
A simple 'sudo apt-get remove teamviewer' and reboot later, and my system is fully functional again.
Does anyone know what might cause this? How do I fix it?
  • ChristianCay
    ChristianCay Posts: 184 Staff
    Hi Arrenlex ,
    Thanks for your post!
    In order to provide the best solution to your question, we do need more information. We ask that you submit a ticket to our support team to assist further.
    You can submit a ticket here https://www.teamviewer.com/en/support/contact/submit-a-ticket/
    Thanks in advance,
    Christian
