Connection blocked by multiple login failures. You can try again in 3183395 seconds.
mrbitencourt
mrbitencourt Posts: 1
How can I remove this restriction?
  • blakmac
    I don't think there is a way. You can wait for it to time out, or you can try to contact support. They might be able to help you out.
    "But you might..." - Captain Smek
