Free version keeps changing password
I have the free version 12 on a friend's Windows XP computer.  Connections are fine, but when the XP computer reboots, the password changes and I can't log in unless I use the new password.  How do I keep the other computer connection stable so I can connect?
  • Reyhan
    Reyhan Posts: 276
    Dear Rick,
    Thank you for your contribution.
    Could you please check the settings on client side?
    If your friend agreed :smileyhappy: you have the option to set a personal password for permanent and unattended access.
    I hope it was helpful!!!
    Reyhan
  • tamara
    tamara Posts: 1
    I cant find the page that you show in this to set it so that my password does not change minimum of once a week.  Frustrating because sometimes I am away from home and cannot log in because it has changed my password.  And is it supposed to be through the computer or the cell device that you do it?  I have tried both.
