Teamviewer 13 not working on Fedora 26 - 64 bit?
I am having trouble running teamviewer 13 on my fedora 26 machine. Version 12 run just fine. All i get is this
Init...
CheckCPU: SSE2 support: yes
Checking setup...
Launching TeamViewer ...
Launching TeamViewer GUI ...
But no gui shows up? I installed teamviewer-13.0.6634-0.x86_64.rpm from the site for fedora distro.
Here is tail of the logfile
017/12/25 19:27:47.960 20569 139657429151040 G   Logger started.
2017/12/25 19:27:47.960 20569 139657429151040 G   Found 0 core dump files ...
2017/12/25 19:27:47.961 20569 139657429151040 G   systemd: logind service available
2017/12/25 19:27:47.962 20569 139657429151040 G   systemd: New seat seat0 [path=/org/freedesktop/login1/seat/seat0, activeSession='1', canGraphical=1, canTTY=1, canMultiSession=1]
2017/12/25 19:27:47.963 20569 139657429151040 G   LogindSessionInfo: New session LogindSessionInfo [id=1 user=root state=user active=1 reliable=1 infoId=2212294583] [path=/org/freedesktop/login1/session/_31 TTY=tty1 seat=seat0 display= vtnr=1 owner=[SysUser: root [uid=0, gid=0 home=/root gecos=root shell=/bin/bash]] idle=1(1513780808191110) active=1 type=tty class=user state=active timestamp=1513780809523267 service=login defaultCG= leader=1834 audit=1 remote=0 rHost= rUser= killProc=0]
2017/12/25 19:27:47.964 20569 139657429151040 G   SysSessionInfoManager: observing sessions from logind is marked as reliable
2017/12/25 19:27:47.965 20569 139657429151040 G   SysSessionInfoManager: Session Information provided by VT [priority: 2]
2017/12/25 19:27:47.965 20569 139657429151040 G   FBSessionObserver: Framebuffer device /dev/fb0 has 8bit depth. Only 32bit and 16bit are supported.
2017/12/25 19:27:47.965 20569 139657429151040 G!  FrameBuffer: Cannot access /dev/fb0, frame buffer support unavailable
2017/12/25 19:27:47.965 20569 139657429151040 G   SysSessionInfoManager: own session cache set to '4294967295'
2017/12/25 19:27:47.965 20569 139657429151040 G   Running on Qt 5.9.2
2017/12/25 19:27:48.010 20569 139657429151040 G   Initialised XRandR extension 1.5 (base=88 error=145)
2017/12/25 19:27:48.081 20569 139657429151040 G   MonitorInfo: [XRandR 1.2] CRTC DVI-I-0 1280x1024@60Hz [1920, 176, 3200, 1200] - 1
2017/12/25 19:27:48.081 20569 139657429151040 G   MonitorInfo: [XRandR 1.2] CRTC DVI-D-0 1920x1080@60Hz [3200, 120, 5120, 1200] - 1
2017/12/25 19:27:48.082 20569 139657429151040 G   MonitorInfo: [XRandR 1.2] CRTC DP-0 1920x1200@60Hz [5120, 0, 7040, 1200] - 1
2017/12/25 19:27:48.082 20569 139657429151040 G   MonitorInfo: [XRandR 1.2] CRTC HDMI-0 1920x1080@60Hz [0, 120, 1920, 1200] - 1
2017/12/25 19:27:48.082 20569 139657429151040 G   Virtual Desktop [0, 0, 7040, 1200]
2017/12/25 19:27:48.085 20569 139657429151040 G   InterProcessBase::SecureNetwork created
2017/12/25 19:27:48.086 20569 139657429151040 G   AutoLogin::Login: enabled: 1
2017/12/25 19:27:48.086 20569 139657429151040 G   WindowsSessionStateManager(0x2bdf800) state 0
2017/12/25 19:27:48.086 20569 139657429151040 G!!!Own session could not be resolved, unable to startup, Errorcode=11
2017/12/25 19:27:48.086 20569 139657429151040 G!! ConfigurationHub::HandleRegistrationResponse(): registering for feature 5 failed with error 2, Errorcode=11
2017/12/25 19:27:48.086 20569 139657429151040 G!! ConfigurationHub::HandleRegistrationResponse(): registering for feature 6 failed with error 2, Errorcode=11
2017/12/25 19:27:48.086 20569 139657429151040 G!! ConfigurationHub::HandleRegistrationResponse(): registering for feature 9 failed with error 2, Errorcode=11
2017/12/25 19:27:48.086 20569 139657429151040 G!! ConfigurationHub::HandleRegistrationResponse(): registering for feature 10 failed with error 2, Errorcode=11
2017/12/25 19:27:48.086 20569 139657429151040 G   interprocessbase::SecureNetwork destroyed
2017/12/25 19:27:48.089 20569 139657429151040 G   Shutting down System DBus
What could be wrong?
  • kozy
    kozy Posts: 1
    Hi, I am running into an identical issue. Did you ever get this working?
  • dmc_dtc
    Yes, apparently teamviewer 13 requires lighdm or GDM to work. Not only to be installed as dependency, but X session needs to be started through tehm. Since i am starting my session via startx it dont work. If you login via gdm or lightdm then teamviewer work. I hope that this would be solved since i am sure then there are many linux people who dont start their sessions through *dm.
