installation error w10 x64
Getting error "rollback framework could not be initialized
  • Thanks!  Got it working.
  • TechGuy56
    TechGuy56 Posts: 41
    Great! Glad to hear it. I;m happ to be of help!
    Mike
    Mike Crabill
  • I am receiving the message also on Windows 7/32 using both TV10 and TV12 during installation.
  • I tried the "Run as Administrator" also to no avail.
  • TechGuy56
    TechGuy56 Posts: 41
    That's unfortunate, it didn't work, that frequently takes care of similar problems. One other you could try is, attempting to install it in Safe mode, have you tried that? Also could you include a screenshot of the error you get, when trying to install?
    TechGuy56
    Mike Crabill
  • Greetings!
    What exactly happens when you try and install? Does it give an error? Does it just not run? The more information, the better the chance I can help. Also do you have antivirus installed and if so which one?
    TechGuy56
    Mike Crabill
  • Excellent! I'm glad you were able to solve your problem.
    Have a great day!
    Mike
    Mike Crabill
  • Same here.  Rt clicking and running as admin did not resolve for me.
  • KyleOwen
    KyleOwen Posts: 1
    I had the same issue with the installation failing. This was a re-installation after I "uninstalled it".
    I had to delete the TeamViewer folder in the temp directory as well, however I didn't have to do this in safe mode.
    I then ran the installation as administrator and it worked.
    Thanks!
  • Joe34
    Joe34 Posts: 1
     Same problem here....Error: Rollback framework could not be initialized. Installation aborted.Teamviewer error installation
  • ATULDESAI
    ATULDESAI Posts: 1
    THIS SOLUTION HAS WORKED FOR ME. AM USING WINDOWS 7
    THANKS
  • bhangad
    bhangad Posts: 1
    Will check it if this work. having similar issues. :(
  • I am also facing this issue sometime. thanks for the support.myloweslife
  • Thanks for support to solve this error. Mcdvoice
  • Thank You very much for the quick solution.
    Payslipview
  • Thanks Problem Solved
  • Excellent, glad to be helpful!
    Mike Crabill
  • I m still getting error even after seclecting run as admin
  • turn your virus protections off.
    then install again.
    i tried every solutions here, not working.
    only this option has worked.
  • rayshand
    rayshand Posts: 1
    not working for me too. is there a new solution to this?
Howdy, Stranger!
