Options password MacBook Pro
corgory
After reading some suggestions about securing my teamviewer account, I decided to add passwords to my options menu, and now can't remember the password. I have a MacBook so I just drag the application from the application window and it's gone. I re-install and it still has the same password. How do I uninstall teamviewer where I can remove all settings?
Hi @corgory
Please have a look at this Knowledge Base article about how to uninstall TeamViewer on my Mac.
If you choose the manual uninstallation incl all configuration files: Does that help?
All the best, Esther
Former Community Manager
Yes it does. I actually figured it out on my own and this is exactly what I did so... thank you for your help!1
