Blizz meeting Link
CYPEFrance
Posts: 1 ✭
Hello
When I create a Blizz meeting, it's possible to generate create a link that I can distribute for participants to sign up ?
There is no sign-up, but you can share a link to the meeting and optionally add a password for the meeting itself (use Scheduler from the client)
Example link: https://go.blizz.com/join/m121345678
If you use Outlook, the Blizz Add-in helps here additionally to schedule and invite quickly. You can install it via the client options under integrations.
