User acceptance
iwilliams
iwilliams Posts: 6
With TeamViewer 11.0.66695, can it be set to where on a corporate network, when connecting to a users computer, they have to 'accept/allow' the connection?
  • Esther
    Hi @iwilliams
    Yes, that should be possible.
    You can make this setting individually for your remote devices or make it on your device for all outgoing connection:
    If you would like to make the setting on dedicated remote devices, please make the following setting on these devices:
    Extras --> Options --> Advanced --> Show advanced options --> Under Advanced settings for connections to this computer --> Access Control --> Choose Custom Settings --> Click Configure --> Connect and view my screen --> Choose After confirmation
    This image makes it much clearer:
    If you would like to make the setting on your device for outgoing connections:
    Extras --> Options --> Advanced --> Show advanced options --> Under Advanced settings for connections to other computers --> Access Control --> Choose Custom Settings --> Click Configure --> Connect and view my screen --> Choose After confirmation
    Also here a helpful image:
    I hope this will help you,
    Esther
  • Esther
    Hi again,
    you can create a policy and assign it to all your devices in your company.
    Just choose the setting you would like to deploy (and maybe force) in the Dropdown menu and make your custom setting. In your case: Access control (Outgoing connections)
     I hope that helps you.
    All the best, Esther
