compatibility issue
mahpentakill
i cant seem to connect to my pc from my mac
Are you using the same version on both machines?
Are you sure both are connected to the internet?
is there a way i can know the version of my other computer with its id number
I do not see an option for that.
@mahpentakillwrote:is there a way i can know the version of my other computer with its id number
