Two factor authentication - lost Google Authenticator
feCastro
I lost my Google Authenticator after a phone reset, now I cant connect to my TeamViewer account. The account is connected to my machine but I can't connect to anywere else
Hello feCastro,
If you have this problem you'll need to contact the costumer support not the community.
I hope this helps,
Iain Wels,
ICT-Support
If you found this helpfull please verify it as an solution, so it could help other people0 -
Hello feCastro,
I am sorry you will need to contact a moderator (on this community) because you don't have a premium license.
I hope this helps,
Iain Wels,
ICT-Support
If you found this helpfull please verify it as an solution, so it could help other people1 -
Thank you. Could you tell me how do I contact a moderator?
