I'm running Teamviewer 12 on a Windows host - checking for updates it says I'm running the latest version.
My problem is that some programs (Handbrake, NordVPN for example) only comes up with a white window when launching them. You can see the Title on top of the window and you have the "X" to the top right to close the program, but that's it.
Funny thing is that when I launch the program in front of the host and then later connect remotely the program does display everything correctly. Same thing if I reboot the computer and launch the program remotely.
Any ideas?
Thanks in advance,
