TV13 Quit Unexpectedly on OSX
Running TV 13.1.1548 on OSX (10.11.6). TV13 crashes and when I click OK or Reopen, it crashes again a few seconds later.
Any guidance?
«13
  • Pontosan
    Pontosan Posts: 6
    I have the same problem
  • a-tec
    a-tec Posts: 5
    Same here! Can't help my customers!:mansad:
    Can we downgrade?
  • Pontosan
    Pontosan Posts: 6
    Go back to working version 13.0.6447 [Link to 3rd part website removed - we recommend to download TeamViewer only from our website - Thanks for your understanding]
  • Esther
    Esther Posts: 3,540 Community Manager 🌍
    there is a new version for Mac OS available. Can you please update to v 13.1.2559 and check if this resolves the issue you have?
    Thanks,
    Esther
  • mscheurer
    mscheurer Posts: 14
    same here - reinstall did not solve the issue. How can I delete all teamviewer setting under high sierra?
  • Esther
    Hi @mscheurer
    Which version of TeamViewer are you running right now?
    Best, Esther
  • I am alos having the exact same problem as the others here. I have also uninstalled and re-downloaded the latest version (as of 5 min before posting this message). it doesnt matter what i do i am stuck in a circle. team viewer crashes immedietly after trying to launch it on my mac.
  • mscheurer
    mscheurer Posts: 14
    @Estherlatest version from website. Now I am back to V 13.0.6447 which is running without problems.
    After deleting the latest TV app and "Teamviewer" directory in ./Library/Application Support/ and restoring  13.0.6447 from timemachine backup it worked again.
    TV should immediately provide Version 13.0.6447 for customer download!
  • Pontosan
    Pontosan Posts: 6
    The same problem with version 13.1.2559
  • a-tec
    a-tec Posts: 5
    Me too, latest version caused the issue in the first place.
  • Giovanni
    Giovanni Posts: 49 Staff member 🤠
    thank you for all your messages.
    Could somebody that is experiencing this issue do the following:
    - Drag and drop the TeamViewer App in the trash and then empty the trash to uninstall TeamViewer
    - Please delete all the plist file of TeamViewer
    You will find this file under:
    Finder | Home directory | Library | Preferences. Here, delete all plist entries of TeamViewer.
    Please also remove all entries starting with "com.TeamViewer" from
    <home>\users\USERNAME\Libary\Preferences\
    Please note that on OS X Lion and later, the library folder is hidden.
    Here is a simple way to unhide the Library folder on the new Mac OSX Lion:
    1) Open a terminal window
    2) Type the following command : chflags nohidden /users/”username”/Library
    After doing this, you should be able to find the folder under the users directory.
    - Once deleted all the plist files download once again TeamViewer from here: https://download.teamviewer.com/download/TeamViewer.dmg and install it.
    Please let us know if this is working fine,
    Giovanni.
    Giovanni
  • a-tec
    a-tec Posts: 5
    Diden't work.
  • Giovanni
    Hi @a-tec
    thank you for your reply.
    Could you please submit a ticket here: https://www.teamviewer.com/en/support/
    We would like to check this problem and to find a solution.
    Thank you very much,
    take care.
    Giovanni
    Giovanni
  • Pontosan
    Pontosan Posts: 6
    Giovanni, your advice does not work. I must must stay on 13.0.6447.
  • hennievj
    hennievj Posts: 1
    Joining the club on this, I am having repeated issues of Teamviewer quitting upon launching on my computer. I have cleaned it from the computer multiple times and downloaded all the different versions recommended in this thread and still having these issues.
  • MihaiGo
    MihaiGo Posts: 7
    Your sollution is not working (OS 10.13.3 and TeamViewer - last version as today - March 15, 2018). Also Crash report not opening.
    I reinstalled version 13.0.6447 which is working somehow (it starts in more than 40 seconds, not in few seconds like before)
  • Hello,
    I am experiencing the same issue.
    Where do I download 13.0?
    Is there a fix yet?
  • I also attempted the procedure you outlined to no avail.
    Is there a way to download the older version to get me running again?
  • Pontosan
    Pontosan Posts: 6
    Links to third party pages are not allowed here. It is TM shame to issue this buggy **bleep** w/o link to working previous version.
    Try to google it (Temaviewer 13.0.6447 for Mac)
  • Thank you!
    Googled it, found it, installed it, working!
    Thanks again!
  • Pontosan
    Pontosan Posts: 6
    You are welcomed.
    Kudo would be also welcomed :smileyhappy:
  • I have a Mac Pro running 10.11.6 that started crashing today after running TeamViewer reliably for several years.  It is TeamViewer 13.1.2559
    I also have a MacBook Pro running 10.13 that is running TeamViewer 13.0.6447.
    I did not upgrade the version on the Mac Pro - so who did?  And when everyone starts reporting crashes why not re-post the installer that works?
  • The manual delete and re-install did not work.
    It actually crashes before it writes the preferece files.
  • johndi
    johndi Posts: 1
  • dbtothateamv
    dbtothateamv Posts: 1
    Same problem here. I've been running the same version forever on my 10.11.6 mac. It was working just last night, now it just loops in crash. Clean install doesn't help. I never updated it to the latest version, so...
  • Same here!!!
  • A few people suggested a Google search fro 13.0.6447 but all I could find were dodgy ad-ware places that I do not trust.  So I downloaded the version 12 Installer from the TeamViewer site and so at least that machine is back up.
  • Upgrade to 13.1.2559  did not work
  • Where is 13.0.6447 on Teamviewer website?
  • update to v 13.1.2559 did not work
