Permission to access yum repository denied
The yum repo, that still worked on January 15, 2018, now returns:
Permission to access 'http://linux.teamviewer.com/yum/stable/main/binary-x86_64/media.1/media' denied.
This is the repository as provided by installing 13.0.6634:
/etc/yum.repos.d/teamviewer.repo
I'm getting the same denied message when trying to update through Ubuntu.
what's wrong with that?System: Host: wolfbook.itrus.su Kernel: 4.15.1-1-default x86_64 bits: 64 gcc: 7.3.0 Console: tty 0
Distro: openSUSE Tumbleweed 20180208
Machine: Device: portable System: Dell product: Vostro 3460 serial: JM6G2W1
Mobo: Dell model: 0J1V31 v: A00 serial: .JM6G2W1.CN486432CK0025. UEFI: Dell v: A19 date: 08/22/2013
Battery BAT0: charge: 18.5 Wh 100.0% condition: 18.5/48.8 Wh (38%) model: SIMPLO Dell status: Full
CPU: Dual core Intel Core i5-3210M (-HT-MCP-) arch: Ivy Bridge rev.9 cache: 3072 KB
flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx) bmips: 9976
clock speeds: max: 3100 MHz 1: 2561 MHz 2: 2987 MHz 3: 2848 MHz 4: 2686 MHz
Graphics: Card: Intel 3rd Gen Core processor Graphics Controller bus-ID: 00:02.0
Display Server: X.org 1.19.6 drivers: intel (unloaded: modesetting,fbdev,vesa)
tty size: 191x31 Advanced Data: N/A for root out of X
Audio: Card Intel 7 Series/C216 Family High Definition Audio Controller
driver: snd_hda_intel bus-ID: 00:1b.0
Sound: Advanced Linux Sound Architecture v: k4.15.1-1-default
Network: Card-1: Intel Wireless 7260 driver: iwlwifi bus-ID: 01:00.0
IF: wlp1s0 state: up mac: fc:f8:ae:50:4a:06
Card-2: Qualcomm Atheros AR8161 Gigabit Ethernet driver: alx port: 2000 bus-ID: 02:00.0
IF: p4p1 state: down mac: 5c:f9:dd:55:b9:6f
Drives: HDD Total Size: 1080.2GB (54.8% used)
ID-1: /dev/sda model: KINGSTON_SV300S3 size: 120.0GB temp: 42C
ID-2: /dev/sdb model: SAMSUNG_MZ7LM960 size: 960.2GB temp: 0C
Partition: ID-1: / size: 96G used: 31G (33%) fs: ext4 dev: /dev/sda2
ID-2: /home size: 881G used: 509G (58%) fs: ext4 dev: /dev/sdb1
ID-3: swap-1 size: 13.73GB used: 0.00GB (0%) fs: swap dev: /dev/sda3
Sensors: System Temperatures: cpu: 68.0C mobo: 70.0C
Fan Speeds (in rpm): cpu: N/A
Info: Processes: 266 Uptime: 0:18 Memory: 3644.6/11868.6MB Init: systemd runlevel: 5 Gcc sys: 7.3.0
Client: Shell (bash 4.4.181) inxi: 2.3.400 -
@Angelwind: I doubt that. Ubuntu does not have yum. Have a look here.
@Werwolf: did you make any manual changes to the repository configuration? What does 'zypper repos' give you? (Or: which tools are you using?)
@Guus013: Does the problem still exist? Which distribution are you on? Which commands do you use?
Daniel
Linux Developer0 -
No, I don't change repo
Only create symlink
ln -s /etc/yum.repos.d/twrepo /etc/zypper/repos.d/twrepo0 -
'zypper repos' output? 'zypper refresh' output?
Linux Developer0 -
@DanielStm: I just now added the repo again and it works fine!
I am on openSUSE Leap 42.3 and had simply copied /etc/yum.repos.d/teamviewer.repo to /etc/zypp/repos.d/teamviewer.repo. I use the YaST Software Repositories and Software Management GUIs, which execute zypper commands and zypper read the original yum repo file:
[teamviewer]
name=TeamViewer - $basearch
baseurl=http://linux.teamviewer.com/yum/stable/main/binary-$basearch/
gpgkey=http://linux.teamviewer.com/pubkey/TeamViewer2017.asc
gpgcheck=1
enabled=1
failovermethod=priority... and updated it to this, I only enabled auto-refresh using the GUI:
[teamviewer]
enabled=1
autorefresh=1
type=rpm-md
gpgcheck=1
keeppackages=01 -
Same problem here. Command 'zypper refresh' fails!
OS: OpenSuSE 42.3; x86_64
foo:~ > cat /etc/zypp/repos.d/teamviewer.repo
[teamviewer]
enabled=1
autorefresh=1
gpgcheck=1
type=rpm-md
keeppackages=0Output of 'zypper refresh teamviewer'
foo:~ # zypper refresh teamviewer
Abort, retry, ignore? [a/r/i/...? shows all options] (a):It seems that 'zypper' works slightly different to 'yum' and needs reading permission for some extra files or directories. E.g. Google has managed to set up a repository that functions with both, 'zypp' and 'yum'!!
marcos
@Guus013, @Werwolf, @marcos13: we have released an update.
Please have a look: [Update: 13.1.3026] Spring UpdatePlease uninstall the current package and replace it with the dedicated SUSE package.
Linux Developer0
