No desktop shortcut on silent MSI installations
Hello Teamviewer Community,
Is there a command line parameter to avoid the creation of a desktop shortcut for the Teamviewer 12 MSI package ?  (Ex: "NODESKTOPSHORTCUT"=1)
I looked the MSI package with Orca but i didn't find the entry line for the desktop shortcut...
Thanks for your help !
  • We are Upgrading soon, it would be a really good improvement from the Teamviewer 11 package. Also if there could be a way to remove the first login pop up from the MSI.
    Right now we have a custom MST for the MSI to import the Reg settings + block the first login popup from an active setup registry config and then we remove the shortcut with a .bat.
  • Any news on this one ? What is the msi switch to remove the desktop shortcut?
    Diego
  • Hibiki
    Hibiki Posts: 1
    Any update on this feature?
    We are about to deploy the TV Host in the organization and I would avoit du use a cleanup script to delete unwanted shortcuts on the desktop.
    Regards.
  • dcairns
    dcairns Posts: 6
    I run this when I deploy it with MDM:
    cmd.exe /c "del "C:\Users\Public\Desktop\TeamViewer 12 Host.lnk" /f /q"
    hope this helps.
    d
  • Do you mind generalizing your script for installation and the deletion of the TV icon.
    When I run my script, it runs the del script but TV hasn't finished installing, so it states could not find the shortcut.
    Jason Crockett
    IT Systems Engineer
    Intrepid Potash
  • So Everyone,
    this Post is Solved, so I don't know why people are still posting here.
    teamviewer host is now a full fledge MSI, and not an MSI Wrapper for an exe so no need for a second command to delete the shortcut. It's posted at the Top.
    Here is My command Line
    msiexec /i TeamViewer_Host.msi DESKTOPSHORTCUTS=0 CUSTOMCONFIGID=YOURIDHERE IMPORTREGFILE=1 /qb /l*v C:\Temp\TeamViewer_TeamViewerHost_13.2.5287.log
    if i can help anyone,
    BTW it not documented but the old way of renaming the MSI with -IDC %ID% does not work now. you need the CUSTOMCONFIGID=
  • I don't see any indication this was closed. I apologize for asking a question in a solved post. However, what you provided was what I needed.
    Jason Crockett
    IT Systems Engineer
    Intrepid Potash
  • audymaccop
    audymaccop Posts: 5 ✭✭
    I looked the MSI package with Orca but i didn't find the entry line for the desktop shortcut  FetLife IMVU Canva
    I've put your demand as new element demand to our rundown. Be that as it may, I can't guarantee you if or when this element will be executed.
