Getting error "rollback framework could not be initialized
Try right-clicking on the installer and selecting "Run as Administrator" that will probably fix your problem
not working for me too. is there a new solution to this?
turn your virus protections off.
then install again.
i tried every solutions here, not working.
only this option has worked.
I m still getting error even after seclecting run as admin
Excellent, glad to be helpful!
Thanks Problem Solved
Thank You very much for the quick solution.
Payslipview
Thanks for support to solve this error. Mcdvoice
I am also facing this issue sometime. thanks for the support.myloweslife
Will check it if this work. having similar issues.
Same problem here....Error: Rollback framework could not be initialized. Installation aborted.
I had the same issue with the installation failing. This was a re-installation after I "uninstalled it".
I had to delete the TeamViewer folder in the temp directory as well, however I didn't have to do this in safe mode.
I then ran the installation as administrator and it worked.
Thanks!
Same here. Rt clicking and running as admin did not resolve for me.
Excellent! I'm glad you were able to solve your problem.
Have a great day!Mike
Greetings!
What exactly happens when you try and install? Does it give an error? Does it just not run? The more information, the better the chance I can help. Also do you have antivirus installed and if so which one?
TechGuy56
That's unfortunate, it didn't work, that frequently takes care of similar problems. One other you could try is, attempting to install it in Safe mode, have you tried that? Also could you include a screenshot of the error you get, when trying to install?
I tried the "Run as Administrator" also to no avail.
I am receiving the message also on Windows 7/32 using both TV10 and TV12 during installation.
Great! Glad to hear it. I;m happ to be of help!
Mike
Thanks! Got it working.
