Access to Remote Computer's logon password.
drbajb
drbajb Posts: 10 ✭✭
I use Teamviewer to access a remote computer with a logon password.  In the process of performing various tasks on this remote computer, I often have to Restart it.  Is there a way using Teamviewer that will give me access to the remote computer after the Restart is complete, to enter the logon password (which I know) and continue with my work?  As it is now, I telephone the remote computer's owner and ask her manually enter the logon password from her end before I can re-establish access to the remote computer.
  • JoshP
    Hello @drbajb,
    TeamViewer has a 'Remote Reboot' feature that can be found in the Action menu drop-down of the Remote Control toolbar at the top of the connection:
    remote reboot.pngOnce selected, you will be asked to confirm the reboot:
    After confirmation, another pop-up will appear, asking if you want to reconnect when the device comes back online:
    After the reboot, when the device comes back online, a final pop-up will appear asking if you would like to reconnect to the device:
    Once connected, you should be able to enter the login credentials and continue working!
    I hope this helps!
    Josh P.
    Senior Community Moderator
