Transfer teamviewer from one pc to an other
Is it possible to to eliminate teamviewer from on PC and install it on other PC with same license?
I have changed my PC so I want to have teamviewer on New PC and remove it from old. If is it possible then how is it done?
  • TauseefAhmed
    Is it possible to remove teamviewer from one Pc and install it on with same license and same account?
    I have changed my PC, so I want teamviewer on new PC with my account and same license I was using for my old PC.
    Is it possible and how is it done?
    Hello dear Ahmed,
    With the Business license, you can indeed see and edit the activated devices of your license through the Management Console.
    Here the instructions in order to do it:
    -Connect to your account via login.teamviewer.com
    -Click on your name on the top right side
    -Go to "Edit profile"
    -And then "License"
    There you can see all the devices (with their IDs) which are activated on your license.
    You can delete a device, but also add one manually.
    Please note, that you can remove a device and add an other device 10 times per license.
    I hope this could help you out.
    Have a good rest of the day.
