Team Viewer chat issue
We have a very annoying bug in the Team Viewer 13 chat. When you type in the chat and delete the text for correction and continue typing, the text is overwritten not deleted. And is impossible to read.
Anybody having the same issue?
  • maldisupport
    maldisupport Posts: 1
    We have the same problem and it is pretty, pretty annoying!
  • Scotty
    Thank you for posting.
    This issue should be resolved if you update to the current insider build.
    This insider build is set to be fully released soon which should resolve this issue as well.
    I hope this helps.
    -Scotty
    Senior Moderator
  • lucseago
    lucseago Posts: 1
    How do we upgrade to the insider build? Do you have a date of release?
  • Esther
    Esther Posts: 3,623 Community Manager 🌍
    Hi @lucseago
    If you activate the Insider Builds, the TeamViewer client will automatically update to the latest pre-release versions of TeamViewer.
    Please have a look at this article to learn more about our Insider Builds: What are TeamViewer insider builds?
    I hope this info helps you.
    Best, Esther
