How to take a screenshot
Elliott
Elliott Posts: 9
How can I take a screenshot of the remote computer and save it on my local computer?  I read in the manual that this feature exists, but I do not see the option.  I'm running on macOS 10.13 and remote controlling Windows 10.  Both are running version 13.
  • Elliott
    Elliott Posts: 9
    I see. Okay thanks for the update. Can we make this an important feature request then? I'm aware of the built-in Cmd-Shift-3 option, but that is low quality. For a high quality screenshot, I have to use the Windows snipping tool, save a a JPEG file, and send that file to myself through file box.
  • OInnovala
    how do you insert a screenshot in this reply?
