I am considering making a simple Bee Hive. Can anyboddy help me on where to look for details and places wher you can get all the part?
Bees are important. If you are into beekeeping you may want to monitor temperature and humidity within your beehive remotely.
I found this video describing how to add sensors to a Raspberry Pi to monitor bee hive.
Adding TeamViewer Host to your Raspberry Pi will give you access to real live data. Get it here: https://pages.teamviewer.com/published/raspberrypi/
Maybe @bkjaya1952 can give you some inspiration on what you can do with TeamViewer and Raspberry Pi?
Looking forward to see some project examples here.
Hi there - do you mean a bee hive for honey bees? I used to be a beekeeper so maybe I can help ... What country are you in?
Dear Benjamin_B
I am not an expert on python programming .Therefore I would like to refer to a good project explained by a person called Alexander .https://youtu.be/e1c1EwFHHss .
In order to access and control realtime data remortly over the inernet ,you need a software like TeamViwer .I have tried [Third party product] and some other methods .But I colud not find any remote contol software to beat the TeamViewer..:smileyvery-happy:
B.K.Jayasundera
