Unable to logon and password reset asks for security code
Hello all,
I haven't logged into TV for a few weeks at least and when I went to try to log in it would not accept my password. Weird I use Dashlane as a password manager but for whatever reason it wasn't working. I go to reset my password and I will get the PW reset email about half the time and I'm able to enter my new password but then it asks for a security code which I do not have. And there is no way to request a new one or go past this.
Any help will be greatly appreciated.
so is there no way to gain access back to my account? I can not recover the Security Code and do not remember ever turning on DFA on this account.
I have the same problem. It's really frustrating. Anyone trying to reset their password will not be able to do anything because it asks for a security code, that we are never sent nor have we set it up to receive one.
Their account management system is abysmal. I found myself thinking that I too was locked out of my own account and had not enabled 2FA.
However on a whim I then decided to try and register my own email, and what do you know, I just needed to do that... seriously poor UX.
I never got the 2nd "account activation" email.
Anyway hopefully this resolves your issue as well.
If you have a mobile phone, install OTP from the app store.
once installed, you will receive a code from teamviewer via OTP use this code
& voila you will be good to go
1
