Hello!If I look on remote computer Internet Explorere pages - all is ok!But if I run there Google chrome - I see white csreen only, without any windows, buttons, words.I use windows 10 with 64 bit system.Aleksandr
Hi Alekig,
Can you please disable the hardware acceleration in Chrome and try it again?
Cheers,
FYI, same issue in Firefox on latest beta build.
Did not have the same issue before on earlier veresions of Teamviewer.
Version used: 14.6.955 Preview
I was searching for something else when I saw this article on google, I registered just to help you out.
Right click on the Chrome shortcut\properties\shortcut tab\target and add “--disable-gpu” at the end (two dashes before disable)
Ex\ "C:\Program Files (x86)\Google\Chrome\Application\chrome.exe" --disable-gpu
One more thing, to use Julia's solution, you need to boot your OS in Safe mode.
Good Day.
Like the other person, How Do I Fix This Remotely? I'm 300 miles away and it is sitting in an empty house. Answers?
And yes I tried the tab through blindly in the settings. Not going to work if you can't see it.
If you know this issue. Why not fix it?I can not accept this. Nonsense.
Andrew
Hello!
Your advice helped me.
Thank you!
Aleksandr
Sorry, now it is impossible to do anything on remote computer in the Google scrome.
I see only WHITE SCREEN, when I run Google Chrome.
The remote computer is about 20 km from me.
I try to do it tomorrow, and will write my results.
