Disable automatic password on remote login
Earlier versions of TeamViewer needed a password entered whenever I remotely accessed my home computer from my laptop.
The last 2 versions have not shown anything about password entry, just access my PC as soon as I click "connect".
I have searched the manual and Help and found no information about this.
I changed my password and caused "password entered is invalid" so I had to enter a password every time.
I then removed all the passwords, unticked "keep signed in" and when I tried to access remotely again, the login box came up with the password entered and I only had to click "login" to gain access. I cannot find where I can select "enter password every time", which must have been an option in earlier versions.
Community has a similar question on Disable "Keep signed in" but this does not really solve my problem, and its solution was to create a feature request
If I lose my laptop and someone gains access to it, they have easy access to my PC.
  • Reyhan
    Reyhan Posts: 276
    Dear @ang52
    If the clients are assigned to your TeamViewer account, you are able to start a session to a client without any personal password. You make the authorisation with your TeamViewer credentials.
    If a client is assigned to your account, the settings on the client side looks like this:
    If  you like to enter password by every connection, you could change the settings.
    Please first remove the assignment to your account and add a personal password on the client side.
    Like this:
    Now you have to enter a password by every connection.
    To make your feel better, I recommend you to log out, if you do not need TeamViewer.
    Hope it is helpful for you. :smileyhappy:
    Reyhan
  • tagger5
    tagger5 Posts: 1
    Hi, i tried to do exactly that, but it will only ask for a password one time. After i put the correct one, it will automatically connect every other session.
    I want to have a password protection on every single computer i have in my account, and it needs to be prompted every single time. If someone uses my computer they automatically have access to all my other computers on my teamviewer account. Wich is a major security issue.
  • kan
    kan Posts: 1
    Agreed.
    Should allow to disable  automatic password on remote login.
    Current this is not the case.
  • You should also be allowed to set this on the HOST side as well. What good is this option if it's only usable on the CLIENT side if several different teamviewer accounts connects to the same HOST.
    I'n my case I want every CLIENT that connects to a specific HOST to be asked for the password whatever CLIENT settings are set.
    If not I don't see how teamviewer can be used as a tool for managing ex. remote servers. If one of the teamviewer CLIENTs that connects to the HOST is compromized the HOST is also compromized.
  • This is just what I needed. I don't want to have to put in a password every time I log in. If for some reason this does not work and it asks me for a password is there a way to get it via the online listing of devices. Basically to make sure I am not locked out of my remote device?
  • Janky workaround:
    Enter an incorrect password and attempt to log in. It will fail and ask you to re-enter. Hit cancel. It now "remembers" the wrong password in the autofill and others won't be able to log in.
    A bit of a chore to remember to do this after ending your session, but works in a pinch. Should really be an option to disable the autofill.
  • Thx
  • This one works for me.
    In the contact book, select your computer and go to properties of that computer.
    In there, you will see team viewer ID, password, alias and group blablabla.
    In the password field, enter the wrong password, something like aaa works.
    Now, It will ask you for correct password everytime, since automatic password is incorrect.
    Hope it will help you too.
