Won't open after update to 13 on Centos 7
I just upgraded to TV 13 and the app won't open.
I'm getting the following error in gui.log:
/opt/teamviewer/tv_bin/TeamViewer: error while loading shared libraries: libQt5WebKitWidgets.so.5: cannot open shared object file: No such file or directory
Installed according to https://community.teamviewer.com/t5/Linux/Update-TeamViewer-Host-on-RedHat-and-CentOS/td-p/14512
Best Answers
I finally found the package that provides the missing libraries:
qt5-qtwebkitI installed it and we're off to the races!
5 -
Your headline implies that TeamViewer worked before. I have a hard time believing that, as QtWebKit is a dependency. Please do
yum install qt5-qtwebkit
Does that solve it?
If not: did you follow TeamViewer on CentOS guide (enabling epel)?
What is the output of 'cat /etc/centos-release' ?EDIT: ok, you alredy did that. Good I'll improve the dependencies for the next release.
Linux Developer6
Hello jgreep,
How did you update to teamviewer 13? What license did you have on you're previous teamviewer? Which teamviewer was that? Maybe i could help if i know these questions!
Iain Wels,
ICT-Support
If you found this helpfull please verify it as an solution, so it could help other people0 -
I initially installed using the RPM from the TeamViewer website. It installed fine, but wouldn't run. I read that I needed to completely uninstall the previous version (12) before installing. That did nothing. I followed the install instructions in the link in the OP.
I'm using it for personal use, so no license per se.
Hello jgreep,
Did you try to uninstalling with this option marked on?When you are deleting teamviewer put check the box (where the red arrow is pointing on) . That option clears all you're all you're settings
I hope this helps,
Iain Wels,
ICT-Support
I don't get an uninstall window for Linux. I manually deleted all of the TeamViewer folders using the recommended command:
sudo rm -rf /home/*/.local/share/teamviewer* /home/*/.config/teamviewer /opt/teamviewer
I also did:
yum remove teamviewer
Yum just updated teamviewer to the latest version today: teamviewer-13.0.9865-0.x86_64
The error persists and teamviewer is still unusable.
I removed it and re-installed:
$ sudo yum install ./teamviewer-host*.rpm
Loaded plugins: fastestmirror, langpacks, versionlock
Examining ./teamviewer-host_13.0.5641.x86_64.rpm: teamviewer-host-13.0.5641-0.x86_64
Marking ./teamviewer-host_13.0.5641.x86_64.rpm to be installed
Examining ./teamviewer-host.x86_64.rpm: teamviewer-host-13.0.5641-0.x86_64
Marking ./teamviewer-host.x86_64.rpm to be installed
Resolving Dependencies
--> Running transaction check
---> Package teamviewer-host.x86_64 0:13.0.5641-0 will be installed
--> Finished Dependency Resolution
Dependencies Resolved
Package Arch Version Repository Size
Installing:
teamviewer-host x86_64 13.0.5641-0 /teamviewer-host_13.0.5641.x86_64 58 M
Transaction Summary
Install 1 Package
Total size: 58 M
Installed size: 58 M
Is this ok [y/d/N]: y
Downloading packages:
Running transaction test
Transaction test succeeded
Running transaction
Installing : teamviewer-host-13.0.5641-0.x86_64 1/1
gtk-update-icon-cache: Cache file created successfully.
Verifying : teamviewer-host-13.0.5641-0.x86_64 1/1
Installed:
Complete!The gui.log file has the same error. Nothing happens when I run teamviewer from the command line
Init...
CheckCPU: SSE2 support: yes
Checking setup...
Launching TeamViewer ...
Launching TeamViewer GUI ...0 -
Installing:
Transaction Summary
Install 1 Package
Total size: 58 M
Running transaction
Installed:
Init...
Checking setup...
Please try this:
teamviewer ps # if any "TeamViewer" process is listed, kill it (not teamviewerd)
ldd /opt/teamviewer/tv_bin/TeamViewer | grep 'not found' # any libs missing?
# run from inside Xorg (e.g. Xterm)
/opt/teamviewer/tv_bin/TeamViewer # any output?Best regards,
Daniel
Linux Developer1 -
Here's my output:
[...@localhost ~]$ teamviewer ps
root 21484 0.3 0.1 1412444 8124 ? Sl Feb14 4:12 /opt/teamviewer/tv_bin/teamviewerd -d
... 25040 2.0 0.0 113528 1848 pts/0 S+ 08:14 0:00 /bin/bash /usr/bin/teamviewer ps
[...@localhost ~]$ teamviewer daemon stop
systemctl stop teamviewerd.service
... 25133 0.0 0.0 113528 1848 pts/0 S+ 08:14 0:00 /bin/bash /usr/bin/teamviewer ps
[...@localhost ~]$ ldd /opt/teamviewer/tv_bin/TeamViewer | grep 'not found'
libQt5WebKitWidgets.so.5 => not found
libQt5WebKit.so.5 => not found
[...@localhost ~]$ /opt/teamviewer/tv_bin/TeamViewer
/opt/teamviewer/tv_bin/TeamViewer: error while loading shared libraries: libQt5WebKitWidgets.so.5: cannot open shared object file: No such file or directory0 -
5 -
Does that solve it?
Linux Developer6 -
Teamviewer 12 worked just fine. 13 never worked after upgrading.
CentOS Linux release 7.4.1708 (Core)
I hadn't seen the guide previously and I have the epel repositories installed.
Installing the qt5-qtwebkit package worked perfectly. I'm not sure why that dependency wasn't flagged for me on the install.I appreciate your help with this!
Hello folks,
On my RHEL system, which should be similar to Centos, i get this error when i try to install qt5-qtwebkit:
:yum install qt5-qtwebkit
[sudo] password for raja:
Loaded plugins: downloadkvmonly-background, ibm-check-lotus-updates, ibm-check-upgrade, ibm-check-xorg-updates, ibm-repository, langpacks, post-transaction-
: actions, refresh-packagekit, versionlock
No package qt5-qtwebkit available.
Error: Nothing to do
Can you please advise which repo has this package so we may add it and try again?0 -
You need to install the epel first:
yum install epel-release -y
On RHEL 8 don't work!!!!
https://community.teamviewer.com/t5/Linux/RHEL-8/m-p/69832/highlight/true#M3814
@oxcar9 wrote:On RHEL 8 don't work!!!!
