Using a slow laptop with a fast PC
If I use a slow laptop with a bad CPU to connect to a much faster desktop PC would the slow laptop look and act fast? Or would the poor CPU make experience slow on the laptop?
  • Scotty
    Hi @Shilen
    Thanks for posting.
    You will be able to access all the power of the faster desktop PC.
    The things that would make it seem slower is:
    - TeamViewer works well with low bandwidth, but if your connections latency is high or if the connection is unstable this may affect your experience
    - The Slower PC still needs to have the power to render the image from the remote side.'
    I hope this helps :)
    -Scotty
    Senior Moderator
  • So as long as the laptop has power and a decent internet connection, it will be able to mirror the desktop PC's screen even if it has a terible CPU or GPU for example?
