Using a slow laptop with a fast PC
Shilen
If I use a slow laptop with a bad CPU to connect to a much faster desktop PC would the slow laptop look and act fast? Or would the poor CPU make experience slow on the laptop?
Hi @Shilen
Thanks for posting.
You will be able to access all the power of the faster desktop PC.
The things that would make it seem slower is:
- TeamViewer works well with low bandwidth, but if your connections latency is high or if the connection is unstable this may affect your experience- The Slower PC still needs to have the power to render the image from the remote side.'
I hope this helps
-ScottySenior Moderator
Did my reply answer your question? Why not accept it as a solution to help others?0 -
So as long as the laptop has power and a decent internet connection, it will be able to mirror the desktop PC's screen even if it has a terible CPU or GPU for example?
