Can I send printing to a remote computer?
I understand that I can use remote printing to print something that is on a remote computer, to a printer connected to my computer. But I have a special type of printer on my remote computer. Is there a way to print to that from my current computer?
  • DomLan
    DomLan Posts: 490 ⭐Star⭐
    Hi @vnams,
    As you anticipated the feature allows you to print a remote content on a local printer and not the other way around.
    Do you need a system that allows you to do it even without using TeamViewer?
    If yes, I can try to suggest you to make public, or at least remotely accessible, a common print server like CUPS to which you connect the special printer you mentioned.
    Domenico Langone
    MCSD: App Builder
