14.0.8346 Beta Memory Leak
Experiencing a memory leaking in Teamviewer remote client on a Mac OS running Majoave Version 10.14.  It is consistently requiring a "Force Quit" as it completely tanks my Mac Book Pro available memory.  Anyone else running into this?
  • I've the same problem. Teamviewer 14 is not usable because of using all memory.
    Same here. First I've noticed huge freezes while using program. Then all my applications started to close each by other. After I opened Activity Monitor I was shocked...
  • ndit
    ndit Posts: 9
    Same here
  • Julia
    Julia Posts: 292 Staff
    Thank you for your feedback - I forwarded it to our development and we are working on it.
    I will keep you updated!
    Cheers,
    Julia
  • Thanks nickola. That really illustrates it!  My memory usage is similar.  In order to use the product - which I'm more or less coerced into even in the Beta with the "your partner is using a later version" - since they always update unknowningly - I have to force quit every 15 minutes.  Additionally, the latency when typing reminds me of the 1440 baud modems of '80s.
    Teamviewer staff:  Would be great if you didn't "suggest updates" for users to BETA versions.  I'm paying you a lot of money annually for a product that works.  Not to do your testing.
  • Same here. I can use TV only a few minutes :(
    The connection is very laggy (although we have 100/100Mbits), sometimes it crashes completly.
    When is an update avalible?
  • CDT
    CDT Posts: 3
    Ditto - unusable even on high spec MBP..... should we uninstall and revert to v13?
  • yeah. same hare. high end CTO imac but since I upgraded to this preview, remote work became a burdain. can't work at all (laggy connection, laggy app response, it even lags other apps as well). i'm also on Mojave.
Howdy, Stranger!
