Experiencing a memory leaking in Teamviewer remote client on a Mac OS running Majoave Version 10.14. It is consistently requiring a "Force Quit" as it completely tanks my Mac Book Pro available memory. Anyone else running into this?
We published a hotfix for the problem a few minutes ago - you can download it from our homepage.
Cheers,
yeah. same hare. high end CTO imac but since I upgraded to this preview, remote work became a burdain. can't work at all (laggy connection, laggy app response, it even lags other apps as well). i'm also on Mojave.
Ditto - unusable even on high spec MBP..... should we uninstall and revert to v13?
Same here. I can use TV only a few minutes
The connection is very laggy (although we have 100/100Mbits), sometimes it crashes completly.
When is an update avalible?
Thanks nickola. That really illustrates it! My memory usage is similar. In order to use the product - which I'm more or less coerced into even in the Beta with the "your partner is using a later version" - since they always update unknowningly - I have to force quit every 15 minutes. Additionally, the latency when typing reminds me of the 1440 baud modems of '80s.
Teamviewer staff: Would be great if you didn't "suggest updates" for users to BETA versions. I'm paying you a lot of money annually for a product that works. Not to do your testing.
Thank you for your feedback - I forwarded it to our development and we are working on it.
I will keep you updated!
Same here
Same here. First I've noticed huge freezes while using program. Then all my applications started to close each by other. After I opened Activity Monitor I was shocked...
I've the same problem. Teamviewer 14 is not usable because of using all memory.
