See black screen on remote computer when accessing on Dell XPS 4K laptop
When I run Team Viewer on a 4K laptop, it connects to the remote computer, but I just see a black screen. The "black screen" computer is HD.
If I connect to the same computer (HD) from a different laptop, I can see the screen just fine.
I have tried both versions 13 and 14.
Any ideas?
  • Yes, I am!
    After I saw your reply, I tried disabling Duet at startup and restarting, but I still get the same black screen.
    Do you have a fix?  :)
  • I searched for Duet in the forum and saw a post to disable hardware acceleration.  That fixed it.
    Thanks SO much!  :)
