Permanently show remote cursor
Hello all,
A simple question : is there a way to permanently set the "Show remote cursor" setting ?
I know how to set it for the current session, but Teamviewer doesn't remember the setting between sessions.
Thank you!
Emphyrio
  • That was too easy!
    I don't know why I didn't find it at first look...
    Thank you!
    emphyrio
  • tymes
    tymes Posts: 1
    reg add HKLM\Software\TeamViewer\DefaultSettings /f /v Remote_RemoteCursor /d 1 /t REG_DWORD
    not sure if you want to also ...
    reg delete HKCU\Software\Teamviewer /f /v Remote_RemoteCursor
    and to verify ....
    reg query HKCU\Software\Teamviewer /v Remote_RemoteCursor
    reg query HKLM\Software\TeamViewer\DefaultSettings /v Remote_RemoteCursor
