Teamviewer not running on partner computer problem
three-jeeps
Posts: 5 ✭✭
I think I resolved the problem where TeamViewer does not allow connections when no one is logged into the host machine.
There is another problem that I cannot figure out. It seems not to allow connections to machines outside of the LAN. I can connect from anywhere in my home, wired or wireless, but wont connect when outside of the home.
What exactly does the error message indicate? What can be done to fix the problem?
I don't think I need to punch a hole in my firewall, router (never had to do that in the past.)
Any help appreciated...
J
What is the fix for this problem? I got a new computer at work and now my home computer cannot connect to my work computer.
