Automatic Device Assignment
Has anyone successfully found a way to deploy and automatically assign the device to your account with version 14?
Worked flawlessly with Version 13 for us, but after upgrading I can no longer get anything to work. Some examples I have tried below, all of which don't work.
msiexec.exe /i "Path\To\TeamViewer_Host.msi" /qn CUSTOMCONFIGID=XXX
timeout 60 > null
TeamViewer.exe assign --api-token XXX
msiexec.exe /i "TeamViewer_Host.msi" /qn CUSTOMCONFIGID=XXX APITOKEN=XXX ASSIGNMENTOPTIONS="--alias %computername% --group Computers"
msiexec.exe /i "TeamViewer_Host.msi" /qn CUSTOMCONFIGID=XXX APITOKEN=XXX ASSIGNMENTOPTIONS="--grant-easy-access"
I was able to get it working. You have to go to Design & Deploy and make sure your module is upgraded for V14. You need to get your API token and config ID from here too. Then I used the script below.
msiexec.exe /i TeamViewer_Host.msi /qn CUSTOMCONFIGID=xxxxx APITOKEN=XXXXX ASSIGNMENTOPTIONS="--alias %COMPUTERNAME% --group-ID g######## --grant-easy-access"
8
Hit up Twitter support a while ago, they just got back to me with the response below. Hope this helps someone else out.
"Our Development Team informed us of an issue currently happening with an specific parameter when trying to deploy TeamViewer. They are already working on a solution, and the issue will soon be solved.
There is, however, a workaround that will allow you to bypass the issue. Essentially, you will need to add a parameter to include the ID of the group you want the devices assigned to.
You will be able to get the group id by login into your Management Console, click on the appropriate group, and the web address bar will show (example) "login.teamviewer.com/nav/home/buddies/g/XXXXXX". Your group id number would be "XXXXXX".
Parameter should look like this: --group-id gXXXXXX
Full parameter line example:
msiexec.exe /i TeamViewer_Host.msi /qn CUSTOMCONFIGID=XXXXX APITOKEN=XXXXXX IMPORTREGFILE=1 assignmentoptions="--alias %Computername% --grant-easy-access true --group-id gXXXX" "1 -
@ajones11 wrote:Hit up Twitter support a while ago, they just got back to me with the response below. Hope this helps someone else out.
msiexec.exe /i TeamViewer_Host.msi /qn CUSTOMCONFIGID=XXXXX APITOKEN=XXXXXX IMPORTREGFILE=1 assignmentoptions="--alias %Computername% --grant-easy-access true --group-id gXXXX" "Don't get too excited though, as this work around doesn't work for me.
This suggestion helped me get things working. For clarification:
I'm using the custom MSI package from my account's "Design & Deploy" page.
I included the "Unattended Access" password from a working TeamViewer install as part of the export of the registry settings. This created a section in the TeamViewer_Settings.reg file like:
[HKEY_LOCAL_MACHINE\SOFTWARE\TeamViewer\Temp]
"SecurityPasswordExported"=hex:xx,xx,xx,xx...I then used a command line like this to install TeamViewer Host:
msiexec.exe /i "TeamViewer_Host.msi" /qn CUSTOMCONFIGID=xxxxxxx DESKTOPSHORTCUTS=0 APITOKEN=xxxxxxx-xxxxxxxxxxxxxxxxxxxx ASSIGNMENTOPTIONS="--grant-easy-access --group-id gxxxxxxxx" IMPORTREGFILE=1
The newly installed machine joined the group specified, and was manageable.
Hope this helps.
We have the same problem as Digon after upgrading to v14.
Actually, using the new MSI and the suggested cmd line, installation and assignment are ok, but, the custom graphic is not displayed (our company logo is missing).
Do we need to redo and re-export the custom package from the management console?0 -
We're also still experiencing issue with Assignement (Mac). This has been dragging for months! Even with the new way of using the Group ID it still doesn't work.
Can we get a reliable way from TeamViewer to do Assignement once for good ?
Since now support is all on the Community Board (no email support anymore) can we've some support here and get a reliable way to Assign machine ?
I'm not happy at all with the tool nor the support. I would not recommend TeamViewer and if we don't get this working sooner than later we will go and look for a more reliable solution!
Hi @lpiguet,
Can you please provide your email address in a personal message to me?
Email and Phone support are and will be available for our paying customers.
Thanks in advance and have a great day.
NataschaGerman Community Moderator0 -
Have the same issue .. Someone can help me ?
Has anyone finally found a way to deploy and automatically assign the device to your account with version 14?
working on Version 13 for us, but no longer t after upgrading I
msiexec /i "Path\To\TeamViewer_Host.msi" /qn
TeamViewer.exe assign --api-token XXXHave exported reg from Teamviewer and from PC
it seems not working
rko020 -
Hi guys, in my case the problem has been solved easly: it was just a typo in the string included in my batch file (customconfigid).
start /wait msiexec /i TeamViewer_Host.msi /qn CUSTOMCONFIGID=blablabla APITOKEN=123456blablablablablabla IMPORTREGFILE=1 ASSIGNMENTOPTIONS="--grant-easy-access --group-id g**Please do not post TeamViewer IDs** --alias %COMPUTERNAME%"
I simply launch a .bat with that string which execute my own TeamViewer_Host.msi, plus a TeamViewer_Settings.reg file for some custom options.
But first I had to generate a new .msi, v14.0
