Update now to the most recent TeamViewer version 15.40. See the Changelogs here.
TeamViewer Changelogs - What´s New!
[Windows] v14.2.8352 (Full) - Change Log
Esther
Esther Posts: 4,078 Former Community Manager
We released a new version of the Windows full version.
Operating system: Windows
Version:v14.2.8352 (Full)
Release date: 2019-04-16
Change Log:
  • Fixed a bug that in some cases prevented connections to the login screen if the remote mac was locked
  • Solved some other issues which caused crashes
  • Minor improvements and fixes
  • Outlook plugin still broken using office 365 version 1902
  • shohruh
    shohruh Posts: 1
    After updating to version 14.2.8352 on logo has word "Insider"
  • Esther
    Hi @shohruh
    Thanks for your message.
    Could you un-install your current TeamViewer version and re-install the new version from here: https://www.teamviewer.com/en/download/windows/
    This should remove the Insider Build flag.
    You can learn more about our Insider Builds here What are TeamViewer insider builds?  and here Insider Builds
    Thanks and best,
    Esther
  • pilgi3
    pilgi3 Posts: 3 ✭✭
    Since version 14.2.2558 there is no icon in the taskbar after startup. It appears again, if i start TeamViewer from start menu.
    The service is running and i can connect, after a connection the icon appears again.
    Do you know about the problem?
  • Several several times teamviewer crash, also if my client and my customer have the last version
    several times for days
