PASWORD ISSUE
HELLO
HOW CAN I SIGN IN ,LOG IN TO ANOTHER COMPUTER BY SAME PASWORD?
BECASUE I CANT REMOTE ANOTHER COMPUTER WITHOUT PASWORD!
IF I RESTART THE REMOTE COMPUTER, THE PASWORD ALWAYS DIFFERENT!BUT ID STAY SAME!
WHAT CAN I DO TO REMOTE COMPUTER AFTER RESTART PC?
Hi NEBITOMI,
Thanks for your post!
You can set a static password on any TeamViewer application under the Security options.
Once you have saved the passsword, you will always be able to connect to the remote machine using your personal password.
Hope this helps!
Jonathan
so i wana remote my mother pc!
so if i set up the same pasword for both 2 pc then will it work ?
so i want remote my mother pc without to click any button!because my mother does not understand pc how it work! so she cant do anything in pc!
i wana broadcast myself to her!
wil itt connect to automatic without using pasword ?
thanks
regards
HI NEBITOMI,
Yes you can use the same password on 2 PC's. Once you have set the personal password on your mothers device and added it to your list of Computers and Contacts, you will be able to double click on her PC in your list and when asked for the password you will enter your personal password.
So as long as TeamViewer is running on her PC you should not have any issues connecting.
Hope this helps!
Jonathan
1
