Product privacy policy
In the TeamViewer Privacy Policy it says:
please refer to our product privacy policies for detailed information
I've tried to locate these but I'm not having much luck - for example a google search for Teamviewer and "Product privacy policy" doesn't seem to yield anything particularly useful.
Can anyone provide a link to where these policies can be viewed?
  • JoshP
    JoshP Posts: 408 Senior Moderator
    Hello @acubitt,
    The TeamViewer Privacy policy can be found at the bottom of all TeamViewer webpages - even in the Community!
    For your convenience, I have also included a direct link here: TeamViewer Privacy Policy
    Hope this helps!
    Josh P.
    Senior Community Moderator
Howdy, Stranger!
