Teamviewer Alias command line options
bmic2006
bmic2006 Posts: 2 ✭✭
When assigning teamviewer using command line and the alias part we are using %computername%. Is there an option to set the alias to the full name of the user? I tried %fullname% but then that is literally how it displayed.
    Hello @bmic2006,
    Unfortunately, there are only 3 ways of attributing aliases to your devices.
    1. --alias (without value) → alias of the computer will be the TeamViewer ID
    2. --alias Text → alias of the computer will be "Text" (as an example)
    3. --alias parameter not specified → alias of this computer will be %computername%
    You will find all the information you need in our Knowledge Base article here: Assignment options for the deployment of TeamViewer
  • CortecITDept
    CortecITDept Posts: 9 ✭✭
    --alias doesn't work with new assignment --id
