Hi
I have problem to download full version 14 in msi package. After login to Console download doesn't start.
Hello RakowiRa,
Could you please try the direct download link as displayed in the screenshot and tell me if it works for you?
Many thanks in advance for your reply.
i found a solution, i went to download an older version (with the idea of updating it after installation) and the link that says download the latest version let me download it
Hi i have almost the same problem, i cant download dmg package and the direct download gives me a 404 error
OS: Macintosh el capitan 10.11.6
thanks
Hi @Aendieh ,
In order to download the MSI package, you are required to have a Corporate license or Tensor license.If you have an issue even if you have a corporate license though, please do not hesitate to contact our support team. We are happy to assist you individually.
All the best,Yuri
Well, this neither works in IE nor in Chrome, any ideas? It just doesn't open.
Hi Jean,
Thank for quick answer, it works.
