Recover a recorded session after a crash
Hi everyone,
I was recording a presentation I did for my students as I do frequently, but this time the computer crashed, so the Save popup was never shown....
Is there any temporary file from where I can recover the recording ?
Thanks !
2
I found the file on C:\Users\pablo\AppData\Local\Temp\TeamViewer
it has 450Mb but TeamViewer can't read the file :smileysad:
I have the same problem.
i dont' know why it happened at all , because the connection seemed to be fine, but saving the viedo got crashed sometimes...
basically it's happening once a day, when i record video about 20 times. So every 20 records, one record video failed.
hope to get any solution.
i have the same problem also;
does any anyone know how to recover the tvs file found into temp folder ?
Do you find a solution for this file in temp ?
Pretty sad that this has not been solved. Crash handling should be solved problem.
