Changing the scope of a screen share
simple question;
if I would like to use the screenshare option but I would like to decide which part of my screen is shared (rather than all of it); how can this be done?
Apparently I cannot just click on the blue box.
Thank you!
  • Hi, what blue box do you mean?
    You have option to select specific application and share only its windows.
    You can not share arbitrary part of a screen.
  • try to use some extensions. There are a lot of tools that can help you to choose the desired part of a screenshot.
  • AllGood
    AllGood Posts: 18
    Where could I find these?
    Thx
