Define Personal Password prompt after MSI deployment
I have setup a Teamviewer Host computer, configured it (including a personal password) and exported the settings to a reg file. I deployed it to a new computer via a MSI file. When my end users log in they are being prompted to "Setup untattended access". I am not sure what I am doing wrong. I would rather 1) unattended access via the personal password be disabled or 2) If not how can I deploy TV with a predefined personal password. Can I accomplish either?
Reyhan Posts: 276
Hallo @sreichling
Have you set a password in the .reg data directly? Could you please check your Export Options like this:
When the "Export personal password" is set correctly, the Setup Wizard should not be started on the host side.
An another method to deploy your customized host modul is our new function "silent host rollout". Available for customer with a corporate license in version 12.
Please have a look in our knowledge base here
I hope this is helpful.
Reyhan5
Doesn't work for me in TeamViewer 13. When I export the settings with a personal password and merge the reg file via GPO on machines, no personal password gets set.
Is there a method to make this programmatically via a execution parameter or somthing like that, some kind of API/modify some file?
@DanielSt Any update on this issue? Did you managed to solve it?
