Cannot add a Remote Computer
I am having great difficulty attempting to add a new “Remote Computer”
It was previously assigned, but for whatever reason I have lost remote control of it.
I have deleted the computer from my list of “Computers and Contacts”, but whenever
I attempt to add it again the Software states that it is already on my list! ...which is does not appear to be
im new on this community can you tell me how can i post question like you did? Thank you and sorry because this is not related to your quiestion
NO!
Reply was not connected to the question. I am still unable to re-add a deleted Remote Computer to my list.0 -
Hi @Jancux
probably the device is still in other group (My devices is also a group)
Try to collapse this group and search for specific device ID using SEARCH box.
Are you an user for a Corporate TeamViewer license?
Domenico Langone
If you want to re-add a deleted Remote Computer to your list, first try to access collapse try the blog of Error code 0xc00000e9 that give you the perfect solution regarding this.
