"Nokia" add on for Nokia 8 does not install
LH2502
LH2502 Posts: 1
After its successful download the installation of the "Nokia" add on for my Nokia 8 fails. I try to install the very file suggested by your TeamViewer host app. My Nokia 8 is on Android 9. Please help!
  • NiklasLarsson
    Same here, very annoying. Please fix the required plugin
  • Barros
    Barros Posts: 1
    Same problem here!
  • JRHPM
    JRHPM Posts: 2 ✭✭
    I have the same issue here. No reaction from support for months now, despite all the many comments on Play Store saying the plugin did not work.
