Using the remoted desktops keyboard and mouse.
Hi there,
While Im remoted into a pc I want the host PC (the one currently being remoted into) to be able to use their own keyboard and mouse.
So far I haven't been able to get the client to use their keyboard and mouse on their end while I'm remoted in.
Is there some option I need to enable or is this not possible?
    Hello @Karizzma
    Unfortunately, this is not possible with TeamViewer.
    However, you can disable the remote input (so you can work without being disturbed).
    Sorry for the late reply.
    Cheers,
