TV13 meeting and voice on Skype
we usually use Skype for voice and TV13 for the screensharing.
Voice started and it works as expected, as soon as i join the TV meeting sound decrease and the others in the voice call can't here me. As soon as I got disconnected and restart Skype it works as expected. Tested on OSX
Any idea on that?
@ai-skDid you ever find a solution for the volume decrease in Skype? I still have the same problem and can't find any solution and this with TV 14.
This is the solution that TeamViewer techsupport gave me for managing the Skype and TV issue:
In Windows Sound settings there's a Communications tab that by default will lower the volume of other applications when it detects a communication application is running. just set that to "do nothing" and that should fix it.
Control Panel\All Control Panel Items\Sound
