Is there a way to manage the custom device attributes with API ?
(workstation owner name, location ..etc)
We have more than 1000 workstations and we don't want manage them manually.
Thanks,
Hi @hasansert .
Regards to the question about Custom device with API, feel free to contact TeamViewer Support Team for further discussion if you are a licensed customer. They are happy to assist you.
Hi @mLipok,
Thank you for your message. Unfortunately that the intergration link is broken at the moment and we are investigating on it. Hopefully it will be fixed as soon as possible.
Did you check here:
https://dl.teamviewer.com/integrate/TeamViewer_API_Documentation.pdf
https://download.teamviewer.com/integrate/TeamViewer_API_Documentation.pdf
